- Oct 29, 2008
- 1
- 0
- 0
Here is the situation:
I have a friend who is around 70 years old. He has a decent rig that has an ATI all in one tv tuner card. He does not subscribe to cable and uses over-the-air antenna for his programming.
He also has a nice 1080p 46" samsung and he recieves all the local channels in great high quality HD. He now wants to eliminate the converter box hooked up to his pc as well as get a better picture on his 30" viewsonic n3000w. Right now he does not have a converter box hooked up to his Samsung. Do you think when it switches in February he will need to hook one up?
The card would have to be a PCI card as his rig is AGP and has no pci-e slots. His comp is a few years old. I was thinking about this
http://www.leadtek.com/eng/tv_tuner/...&pronameid=220
Also, according to viewsonic his monitor is hdtv ready but i do not see how it could recieve an hdtv signal. I could not find a tv tuner card that had 20 pin dvi out.
So i need some help: Help me find a solution to remove the analog to digital converter box as well as recieve hdtv singal on his monitor from a OTA analog cable and via his PC input.
