monitor troubles
ecaandrew
49
well i just built a new computer, and a LCD monitor, when i play games on the new pc with the LCD monitor, after about an hour, the monitor will turn off, and the orange light will come on, than if i turn the monitor off and back on, it will turn off in about 5 seconds and go back to the orange light, and this will happen constantly... so i switched it up with a CRT monitor and it works fine. but I used the same LCD that kept turning off and used it on my other pc, and it worked fine for like an hour, any ideas? thanks.
asus a7n8x-x
rosewill radeon 9600xt
rosewill r710J 17" LCD monitor
i tryed doing driver updates and windows update
if you can help, thanks.
