I'd like to have my Monitor work with my Xbox 360, the video works. The sound doesn't.
Here's my setup:
Monitor Connections:
-HDMI Audio Output.
-HDMI Jack
-Con (Yellow port)
-S-Video Port
-Red/Blue/Green Ports.
Xbox 360 Cables:
There are 6 cables. A par of three are coupled together.
--Red/Yellow/White and Red/Blue/Green.
--This system was bought the week 360's were released. So there's no HDMI cabling.
Speaker System:
Logitech z5500 5.1 Surround Sound
Sound Card:
-XFi-Elite Pro
--Contains one free input 3.5mm jack.
Whats connected:
-Monitor's (Red/Blue/Green) Ports connected with the Xbox's (Red/Blue/Green) cables, the -Xbox's Red/Yellow/White are not connected into anything.
Whats the problem:
No sound. Video looks alright I suppose. Wish I had 1080p (Which this monitor supports) 🙁
Questions:
1-Is there a way to do this without adapters/extra cables? Like a way to transmit the signal (Xbox => Monitor => PC)?
2-Monitor/PC not near Xbox. Do I need to split my Xbox cabling?
3-Do I need a adapter to plug the Xbox's audio cables into my Soundcards input 3.5mm (headphone) jack?
4-Is there a way to get an HDMI cable for my Xbox 360? Or do I need an entire new system for that?
I would also like to have my Cable Box plugged into my Monitor in the near future as well. Would I need to spend upwards $70-100 for some sort of switch that would allow me to switch between the processes? If so, I'll put this off and by a cheap part/adapter/cable or whatever I need to purchase based on your recommendation(s).
Here's my setup:
-HDMI Audio Output.
-HDMI Jack
-Con (Yellow port)
-S-Video Port
Xbox 360 Cables:
Speaker System:
Sound Card:
-XFi-Elite Pro
Whats connected:
Whats the problem:
Questions:
