Monitor Suggestions
crisscross
1,598
I was looking at the Catleap when I noticed the Microcenter Auria and the Overlord Tempest.
Between the three which one would you recommend? I live in India so RMA is not an option so would want to pick up something which has the best quality and reliable.
As for uses, it will be used for movies and work with little or no gaming at all.
Thanks!
ShintaiDK
20,378
Is the catleaps 400$? You can negotiate yourself to a better dell u2713hm for around 550$. And get world wide support.
VulgarDisplay
6,188
Also, I have the Powercolor 5570 with DVI and HDMI Port.
You really don't want such a high resolution monitor if you are using a 5570. If you don't plan on gaming you could get away with it, but if you plan to game expect framerates in the 0-10 fps range.
VulgarDisplay
6,188
Yes. I don't game at all so that won't be a problem.. lots of HD movies though.
I've never used a 1440/1600p monitor before, but I know what 640p upscaled to my 1080p monitor looks like hot diarrhea. I can only imagine that 1080p HD content will also look bad when it's upscaled to 1440p.
