Monitor/Sound issues.
Platypus
31,046
321
Anyone know why when my speakers are really loud (thx klipsch 2.1) the corners of my monitors flutter. I thought the wires were video shielded. It's becoming quite a problem and I really cannot move them farther way from the monitors..
Any way to fix this?
Atrail
4,326
The sounds waves must be shaking it.
Or the vibration from the speakers stands on your desktop.
Why are you thinking it's cause the wires?
Yomicron
1,735
There are a couple of possible causes, the speakers might not be properly shielded (unlikely being that they are Klipsch). Another possibility is that the wires for the speakers are running too close to your monitor, or its cable. The video cable is shielded, but I'd bet its shielded to protect it from "normal" noise, not from the relatively high magnetic field generated by speaker cable.
