Monitor: Sony E400 vs. G400
alfresco51
12
Please tell me, are the only differences between the E400 and the G400:
- Horizontal scan range up to 107kHz on the "G" and up to 96 kHz on the "E"
- Refresh rate at 1800 x 1200 is 70Hz on the "G" and 60Hz on the "E"
- The G400 has a feature called "Image Restoration" whereby the user can restore contrast and brightness to original factory settings. The E400 does not have this feature.
So, is that it??? Furhtermore, is that image restoration feature all that imprtant? Can't the user just manually adjust contrast and brightness as the tube ages?
As always, thanks for your imput.
Midnight Rambler
<< So, is that it??? Furhtermore, is that image restoration feature all that imprtant? Can't the user just manually adjust contrast and brightness as the tube ages? >>
Yep. It's not really much of a &quot;feature&quot;.
On the other hand, I have seen the G400 going for about the same price as the E400. In that situation, I would go for the G.
The Wildcard
2,743
I also think that the G400 has some &quot;special&quot; high contrast coating or something, but i also think that's some marketing bs.
