Monitor res/Vid card res mismatch
EmilG
22
From my experience with an LCD monitor the best picture I get is when the vid card res and monitor res are the same. I'm looking at widescreen monitors and there doesn't seem to be an exact match. Is there a way to disable the scaling on a WS monitor and accept the black bars around the picture? The bigger monitors are 1680x1050, the res my vid card has which matches the game is 1600x1024 which would be pretty close.
Thanks
BassBomb
8,390
If you have an nVidia card you can go into the Control Panel and for Digital Flat Panel Scaling select Do Not Scale
Most monitors won't do 1:1 on their own
You can't select 1680x1050 in the game? check www.widescreengamingforum.com to see if you can modify it to run at your res
EmilG
22
I have a CRT right now and that resolution doesn't show up as an option so I was wondering if it was available.
Thanks
Aug 1, 2004
77
The resolution normally doesn't not show up as an option unless your monitor supports it. Borrow a widescreen monitor to hook up and it'll show up.
bobsmith1492
3,875
Huh, nice card - it should handle any resolution you want. I don't know if WOW supports widescreen, though...
