Monitor/Res Refresh probs plz help
KodeRhed
50
Hiyas
my 17" monitor blew so im back ot using my old 14" for a while..but i have a problem...i dont have the drivers for it...its an osborne monitor and they dont have a site or drivers ive been told they jsut rebadge peoples monitors so i would have to use another driver its model is MPV1024NI
anyway i set it up as a standard 1024x768 svga it works fine in 1024x768 but it wont do 800x600 or 640x480...because its trying to do higher than 60hz refresh rate...my old monitor had a check box in XP to click to disable to reses it cant do..but this one doesnt...is there someway to limit it only to 60hz so i can use games that use 640x480 for htere menues etc cause its all doubled and lined and fuzzen about and i cant see sheeet when its in anything but 1024x768
im using windows XP...will put 2k pro back on if someone tells me a way to limit to 60hz im using a 3dprophet 2 4500 tv out (kyro 2)
PLEASE HELP!! =P i cant play anything but Ultima 9 (which isnt a bad thing bu after a month it gets boring..considering i beat it 2 years back)
Thanks in advance
