I've seen this a couple times, The monitor gets a kind of yellow green glow. I think it is the blue gun that quits putting out.
because there is no blue in the OSD. Nnow the monitor would do this intermittent for years. but usually a giggle of the cord would fix it.
Also one time when a monitor with similar symptoms was taken in the guy said just needed a new VGA cable.
So I took the case off(carefull all the time) and looked at the external surface mount vga din plug and the solder joints were shot so I re flowed them but it didn't help. I'm no tech by any means. I was wondering if anyone with relevant experience would have a suggestion.
This whole situation and solution would only have relavence if it was one of those things that go like this .....80% of the time it is the solder break at the blue gun mosfet caused by thermal cycling.... there are lots of examples of things similar to this so just askin if this is one of them.
Thanks and HNY
s
Thanks and HNY
s
