DPOverLord
Hey guys,
I am building a new system and now need to select a monitor. The system thus far is:
CPU&Mobo: i7-930/Gigabyte X58 or 875K/P55
Ram: Gskill 6gb(triple channel) or 4GB Gskill
GPU: Leaning towards a 1GB Nvidia 460
Powersupply: Seasonic 750Watt
My hiccup right now is the monitor I was going 3d but decided the investment of $440 which makes me lose so much real estate space vs my current 22 iiyama CRT is not worth it. I want a significant improvement and I am leaning towards the +27/28 realm.
This leaves me with a new budget being adjusted from 0-$300 to $300-$450 for a +27 monitor. The Haans 28 at Newegg seemed really good but if there is a monitor with better technology &visuals I will spend more than my $300 allowance. However, I would want a significant improvement over the Haans which I was leaning towards.
What do you think? Is my choice bad or do you have some better ideas?
Thanks a million!
Thanks a million!
