Monitor problem
InTheClouds
109
OK, here is the deal. I have a monitor that I was told to trash but I believe it may be fixable. If I can fix it I can have it.
Here is the diagnosis: When you power it on, the light indicator will go green(like it does when it is working fine)for a second but will then go orange and start blinking. I can hear a clicking sound that goes along with the blinking.
Any sugestions? It sounds to me like a relay or something but my opinion isn't really worth much. I have tried it on different systems and get the same effect.
Thanks in advance.
1greatguy
198
is it the monitor or the computer? good luck getting it fixed, you didn't say what size it is, if it's small (17" and under) it's probably not worth fixing
