My button on my monitor (which pops out when you press it, not like those that you can press, and they stay in until you press them to pop out) has been jammed or something, so I took the button part of the monitor apart, and found that it's a little disk that touches the outer part of the curcuit board, but when it gets pressed in, the outside, and inside of the curcuit board gets touched by the button, and hence there is a connection, so all I had to do was to get the disk to flip back to the curved shape, but now I can't get the button back together, all I see are two rings, one ring which is touched by the outside of the disk, and the inner ring, which gets touched by the inside of the button when you press it, so as I figure it, I need to get a piece of metal to touch both rings, so I can make them establish a contact. Can anyone help me, or tell me what to do?
