Monitor Opinions
Gamerguy68
95
Anyone have an opinon on a decent 17" flat screen (CRT) for gaming? Don't want to spend too much though :)
BoomAM
4,546
he said CRT not LCD tart666, easy mistake to make though as he said flat screen.
take a look at my post, also bout "17 monitors.
Here
Gamerguy68
95
Thanks for the replies. I have been looking at the XIOD (Samsung UK) monitor and it is decent looking. Others are LG and Hansol. Have you made a decision yet BoomAM?
chizow
9,537
You guys should consider 19'' CRT's for gaming. Its a huge difference over 17'', and given the current prices of CRTs, you wouldn't be paying vastly more in price from even a year ago. Also, 19'' tend to have much smaller footprints than the monstrous 20''+ CRTs, and there are newer 19'' that make a conscious effort to keep their footprint small. 19'' are particularly important for FPS games, but it also makes a huge difference in games where you can up the resolution and see more (RTS games) and even in daily applications like your windows desktop, web browsing, typing papers, working in spreadsheets, etc. Just go into a store (not to buy, but to compare) and its cleary obvious. I've always been of the opinion that you should never skimp on your monitor, since that is the only part of your computer/upgrading that you ever SEE while you are using your computer. No point in spending tons of cash on a nice video card, cpu, etc when all you are doing is cheating your eyes of the experience.
Chiz
ironique
498
I know you asked about 17" but another good option in my opinion is the samsung 19" Syncmaster 955DF. It's a flat screen CRT that goes for as low as $190 (pricegrabber.com). Remember, monitors aren't things you buy every day, so when you go out to buy one, try and get the largest screen size and best quality possible. I think the 955DF fits that description quite well.
Gamerguy68
95
Thanks for the opinions. I was wondering if the 19" was worth the extra $$ and then I came across a XIOD (Samsung UK) 19" EZ-Flat for £129+vat. Whereas, the 17" is £99.99+vat. Not too much difference in price.
BoomAM
4,546
try www.overclockers.co.uk
you can get some good deals from them.
no decision yet gameguy, prob gonna get the monitor in the january sales, as you can sometimes can pick up some good deals then.
BoomAM
4,546
where did you see the £129 samsung monitor at anyway. that seems like a very good deal.
im guessing that its from a UK store cos ure quoting in £`s not $`s.
Gamerguy68
95
I know what it's like trying to make h/w decisions
So many to choose from and too tempting to buy extra toys along the way :D
Gamerguy68
95
Correct..I am in the UK.
I seen it at Scan
Yes, it does seem to be the best deal so far. Been doing some looking around and nothing else come close.
