im planning on buying one of these monitors.. the NEC is about $5 more where ill be buying them.. I'm not too up on monitors though, so im looking for some opinions..
the nec is a 17", and tops out at 1280x1024, 66hz, with 0.24-0.28mm variable dot pitch / 0.20-0.25 mm horizontal according to their site..
the aoc is a 17", and does 1280x1024, but only at 60hz (this is worse, right?) .. but it has 21mm dp(H), 0.25mm dp(D), according to aocs site..
so which is better? i plan to run whichever one i get at 1280x1024.. i know that a smaller dot pitch is better, but is a difference that small noticable? im leaning more towards the nec..
thanks
thanks
