Monitor issue
KeraptisBlah
Hey all
I've had my monitor (an Orion 19DFLB) for two months or so now, working without issue. Today I got home and the power indicator light is flashing, and there is no display. My second system's monitor (from an old Gateway) works fine on both systems, using either power cord. My younger sibling, when questioned, tells me that the image was "partially black and fuzzy" when he brought it out of power saving, and soon after went totally black. I assume something inside died, but just in case I don't have to deal with Orion (who has no customer support section on their site to speak of, and it was warrantied through the manufacturer only when purchased from Newegg) I thought I'd throw this out there.
Any ideas would be greatly appreciated, thanks in advance.
bendixG15
3,483
You got a two month old monitor that died...presumably has some warranty.
All you can do is chase the manufactorer and the retailer.
(yes, complain to both of them at the same time)
You might get some relief from one of them
Good Luck
