Monitor - Input lag and different monitors
wand3r3r
3,180
What are the acceptable levels of input lag? I assume there is some room for debate since IPS vs. TN vs. 120/144Hz monitors will all vary.
When looking at a budget 4k monitor I'm just debating if 4 frames is terrible, it kind of sounds like a lot of lag (58ms, g2g was 6ms measured).
Does anyone have a quick ballpark for the monitors currently in use for gaming?
IPS input lag
TN (decent monitor)
TN (poor monitor)
120/144Hz (good-lowest input lag)
BrightCandle
4,762
IPS - at maximum about 30 ms peak, 8ms minimum, average around 16ms
144hz - around 1-4ms
wand3r3r
3,180
Thanks, so 58 ms is actually shockingly high. Good to know, I've been debating a cheap 4k monitor and this is the only (major) flaw.
Do you know what the average run of the mill 1080p TN monitor is? Is there a huge difference between them and IPS?
Eymar
1,646
14
Yes, 58ms is pretty high. Maybe the monitor has a game mode? I'd say most TN monitors are class 2 (under 30ms as classified by tft}:
Class 1) Less than 16ms / 1 frame lag - should be fine for gamers, even at high levels
Class 2) A lag of 16 - 32ms / One to two frames - moderate lag but should be fine for many gamers. Caution advised for serious gaming and FPS
Class 3) A lag of more than 32ms / more than 2 frames - Some noticeable lag in daily usage, not suitable for high end gaming
All the monitors listed in this review are under 40ms:
http://www.tftcentral.co.uk/reviews/lg_34um95.htm
Average Lag comparison from above review: http://www.tftcentral.co.uk/images/lg_34um95/lag.png
96Firebird
5,749
345
I've never noticed input lag, but apparently my U2412M has 9ms average input lag, 20ms max. This is an IPS monitor, but I've heard most IPS monitors have higher input lag?
wand3r3r
3,180
Thanks for the info and links.
The Samsung 4k screen has pretty high input lag. I'm guessing most of the 28" 4k screens share the same panel? The dell 32" is somewhat better, but it's $1500+.
(image source http://www.tftcentral.co.uk/reviews/lg_34um95.htm)
wand3r3r
3,180
Interesting, so those two don't seem to have bad input lag.
The samsung has been on sale and has been catching my eye, but I was actually looking at this one atm (AOC).
http://www.aocmonitorap.com/root/hk_en/product_display.php?id=556
I've been anxiously waiting for the next wave of new displays to come since each wave has brought the price down significantly. If I knew it wouldn't drop for a year it'd be easier to buy but it's dropped like a rock in a year (18mos?) from $3,000 to $600. It's seemingly on the cusp of another price segment drop. Since none of the cheap displays are special, other than the amount of pixels, I'm biding my time.
3DVagabond
11,951
204
This is the best info I've found, too.
Input lag and response time are not the same thing. Some IPS monitors, Dell in particular, have gaming modes and are quite fast overall. Also, monitor companies lie about screen response rates.
