Monitor hurts my eyes........
cdrsft
I just bought a massive Samsung 22" flat screen.
I notice, however, that my eyes become tired or sore fairly quickly, something that never happened with my old (smaller) monitor.
Does this relate to the size? refresh rate? radiation?
I need to make some adjustment because Im going crazy. Right now I'm running 1024x768 @ 85Hz.
you might try running a higher refresh, or turning the brightness contrast down a bit... bit tubes hurt my eyes too, i perfer LCD screens, but they cost much more.
you also got to remeber theres much more light comming from the monitor hitting your eyes
Refresh rate is one thing that can cause eyestrain however in your environment, you are likely to find several things that can cause eyestrain, including glare on walls and reflections on the computer screen itself. Minimizing reflections and reducing ambient light are particularly important aspects of your physical-viewing environment. When your monitor power is off, it may surprise you to find that one of the reflections that you see is your own! In order to minimize reflections of things in front of your screen other than lights - including your own face - it helps to reduce the general light level (ambient illumination). Use window shades, blinds, or drapes to block out excessive sunlight, also reduce the internal ambient light if outside light cannot be reduced. Use proper lighting, overhead fluorescent lights tend to be an excessively bright source of ambient illumination, in addition to facilitating reflections. Reduce the lighting by using fewer light bulbs or florescent tubes or use lower intensity bulbs and tubes. I recommend using indirect lighting with a dimmer control, such as stand up halogen lamps that reflect light off the ceiling.
Once you have your environment set up, reduce the contrast setting of the monitor. Resist the temptation to run your monitor too bright. White should be a pleasant white, it doesn't have to illuminate your room. Operate your monitor only at a comfortable brightness / contrast level. Not certain why you are running a 22" monitor at 1024 x 768 at 85Hz. I would recommend running it at 1280 x 1024 at 85Hz or 1600 x 1200 at 85Hz and use the scaling features in windows to increase the size of fonts etc. This may help your eyestrain.
Good Luck
I would suspect that its just because of the massive size and you sitting up close. Think... if you were sitting in front of a 20 inch television compared to a 32 inch television at the same distance. I would think that your eyes would get tired far faster in front of the 35. Your resolution is quite low for a 22 inch monitor though. Even on my 17 inch, 1024x768 looks too big, but i guess thats personal preference. I doubt its a refresh rate problem as 85 is plenty at any resolution.
From what I know, it's a combination of radiation and glare from the computer screen. I used to have the same problem at work, because I had to sit so close to a big monitor, and I stared at it all day. The solution is to buy an anti-radiation, anti-glare cover for your monitor. I've got one from kensington, and it works great. My eyes never hurt. It's worth the 20 bucks.
