Monitor hardware status such as CPU temperature
dejunjing
The Mobo BIOS showes some of these hardware running status, but I am wondering whether there are some monitoring applications under window. Which one is the best? Thanks.
Actually I have an Asus board and I just use AsusProbe. Motherboard monitor nearly caused me to fry my cpu, it was reporting all the temps 10C lower than they actually were. Make sure that MBM readings correspond with your bios readings, then go ahead and use it.
AsusProbe is what I use and iv had no problems so far at all, it takes very little resources and doesnt look fancy or anything. Plus it will report the correct temps guaranteed.
