Monitor going?
sawhizzo
15
rachel: should my comp screen be making an annoying high pitched sound?
qkslvrwolf: no...
qkslvrwolf: no it really shouldn't
rachel: if i hit it it stops
rachel: but it starts up again after a while
Is this the sound/sign of a monitor going? Never had one die on me so I wouln't know.
Mavrick007
3,198
It could have some small resister going in it or something. I had a monitor go and it made a loud snapping sound after awhile and I had one that made a sound and eventually I couldnt' get certain resolutions out of it but it was easily fixable and it didn't cost much to fix it (the labor cost more than the part).
It could be a number of things but if it's an older monitor and it is small (ie. 15 or 17") then it might be worth it more to buy a new monitor cause the cost might be more to fix than it's worth.
