Monitor Geometry Fix When OSC Don't Help
webley
1,069
It is common for Aperture Grille monitors to have some geometric distortion that the on-screen controls can't fix. The most common is vertical pincushioning where horzontal lines appear bowed or the corners bend out and look funny. I learned that one way they adjust this in the factory is to glue little magnets or rotate little magnets on guides inside the monitor by hand to adjust the picture geometry. Dangerous high voltage exists inside so don't open your monitor unless you are trained to work inside. I didn't open mine at all but found an external-only solution.
To make a long story short, I mostly eliminated this bent corner effect on a 21" Trinitron by wiring tiny high power magnets to the OUTSIDE of the monitor to bend the lines straighter. It looks much better and didn't seem to hurt convergence or mess up the display very much at all. It took a lot of experimenting to find where to place the magnets though. Some places it can mess up the screen. I used the magnets from a dead hard drive but any tiny high power magnet should work (especially rare earth types like samarium cobalt magnets).
I would advice you NOT to open your monitor and put the magnets inside because of dangerous high voltage in there. That's why I placed mine outside the monitor case.
jamarno
1,035
It's possible that an internal magnet fell off in shipping, or the yoke (electromagnet around the neck of the tube) had one of its rubber centering wedges dislodged.
Some monitors have an internal pincushion adjustment, it must not be touched except with a high voltage screwdriver with a plastic shaft. Other monitors allow the geometry to be adjusted through a technician's set-up menu that can be accessed either by pushing a special combination of buttons on the front or with some interface hardware that plugs into the back. The interface may be expensive (I've heard Samsung's is $200-600) or cheap (Panasonic & some Viewsonic - $10 in parts and $2 for the software).
webley
1,069
Interesting jamarno. I'm glad I didn't have to open the monitor. That would void the warranty too I suppose.
