Monitor flickering
tvfreakazoid
264
I just noticed that my view sonic A90f+ crt monitor (19inch) monitor is flickering around the edges of the screen. Its kinda hard to explain it. I want to say its kinda like a light vibrating look to it. Is this bad? I have the resolution set at 1152 by 864 and I have it set at the highest hertz which is 75. I thought maybe because the resolution is high I set it back down to 1024 by 768, but the same problem keeps happening. Any ideas?
airhendrix13
427
Try lowering the refresh rate down to 60 hertz. If that doesn't solve it then the monitor might be going bad, because I doubt it has anything to do with the GPU.
nova2
982
IIRC I have one CRT thats been doing that for awhile, but it hasn't died yet.
