ReinhardHeydrich
HELLO,
A PC that I just built has monitor flicker that intensifies during HardDrive access. It also has strange crashes sometimes, like when I try to print a picture.
Also, when it starts, after the Windows XP loading screen finishes, the screen turns black for 30 seconds, and I hear one (or two) clicks from the Power Button of my Antec case. Then Windows XP comes to the login screen.
Do you guys think that these problems are connected? I am guessing that it could be the Power Supply, although it is a 430W. It is a generic Power Supply that came with the Antec case. What do you think? Would a defective (or low quality) Power Supply cause these sort of problems?
I appreciate any help very much.
THANKS
THANKS
