monitor flashes on, then goes super dark
kcbass
1,378
I'm trying to fix this monitor...when I plug it in and turn it on (on both the VGA and DVI inputs) the monitor comes on perfectly, and then goes super dark. The image is still visible, but you can only make out borders and such. This leads me to believe it's a power problem, but it's a nice monitor, so I wanna try to fix it. Any ideas as to what may be going wrong? What's the best way to open up an lcd without damaging the casing?
Any input is appreciated.
Thanks
kcbass
1,378
Thanks for the info. I took the screen apart last night, but didn't go deep enough to the backlights to get a look at them. I think I'll try again soon now that I know what to look for.
