Hi as many of you know I've been trying to get my Monitor fixed by Sony. Well my last attempt failed again, I called their 800 number to get the holes on my glare coating or atleast what appears to be holes on the glare coating fixed... When the monitor is on, the holes is brighter compared to rest of the screen which makes them look like dead pixels, but if you change the background color the holes change colors too and if you look at it from an angle it looks like the holes are inside the glass and when you run your finger thru the hole you really can't feel it... Which makes me think that they are indeed inside the glass
Sony is saying that it is MY FAULT for cleaning the monitor, eventhough I cleaned the monitor using a product they recommended called Klear Screen
I've talked to several Monitor Techs and most of them said that AR and UV Coatings are sandwhiched between glasses and are not on the surface of the monitor. Is this true? And another thing how can something like this which I DID NOT CAUSE not be covered by the warranty?
Let me know as to what else I can do, I don't want a $1500 monitor yo go to waste.. Thanks for all the advise...
