Monitor does not detect signal from new tower (Velocity Micro Edge Z40)
tsheehan
So I just recently bought a new Edge Z40 from Velocity Micro.
I have set it up as directed but my monitor, a working HP 2311xi does not detect a signal with tried and tested VGA DVI and HDMI cables.
I:
Unboxed it
Plugged it into an US-EU adapter (I'm in Europe)
Plugged that into a surge protector
Turned on the surge protector
turned rocker switch on the PSU on
Pressed the power button
LEDs light up, fans spin, the HDD vibrates, I put my Windows 8 disk in the optical drive and that spins, the MemOK! LED that signal a compatibility or installation problem with the RAM is NOT lit (no problems), the green LED next to the SATA 6Gb/s port is lit, and everything seems to be working fine.
Next I try plugging connecting my monitor, first with VGA, then DVI, then HDMI, but to no avail (I would try displayport but my monitor does not support it). The cables were secured at both ends, the monitor was on. It showed that it was scanning all 3 possible inputs, but reported "no signal" and went to sleep.
Since then, I tried pushing on all the connections to make sure the power supplies were connected properly, the connection from the video ports to the motherboard were firm, rearranged my two 4GB DDR3s, and tried using a step-down transformer with the 110V setting on the PSU rather than an adapter with the 230V setting.
Also, I'm not sure if this was initially there, but when I turn on the computer, after a few seconds I hear a short high-pitched 'blip', and a few seconds later, a slightly lower-pitched and longer 'bleep'.
Specs of the computer are as follows:
PSU 700 Watt Velocity Micro® Power Supply
Motherboard Asus® P8Z77-V LK Intel® Z77 based chipset, ATX Motherboard
Processor Intel® Core™i5-2500K processor, quad 3.30GHz cores, Hyperclocked to 4.0GHz
RAM 8GB DDR3-1600 Dual Channel Memory (4x2GB)
Graphics 1GB eVGA™NVIDIA® GTX650 GDDR5 video card (GeForce GTX 600 series)
HDD 1TB 7200rpm SATA 300 w/NCQ
Thanks in advance for any help you can give! 🙂
P.S. The computer seems to be behaving normally besides the lack of connection to the monitor since after leaving it on without doing anything to it for a while, I think it goes to sleep since it appears to turn off, but 'reboots' quickly when I press the power button again.
Ensure you have the VGA/DVI/HDMI (whatever you are using) connected to the videocard and not the onboard video header.
You can also try connecting the monitor to the onboard video, which your motherboard has and supports. If the system boots, go in to the UEFI BIOS and make sure the system is set to initialize the PCIe video card as the default display. Then, shut down, reconnect the video card to the monitor, and try to reboot.
