Is there a way to monitor the dnetc output when its running as a service? By that, I mean is there a way to view the console window? Also, does anyone know where I can get wintop so I can check to see if dnetc is running in the background or not? Thanks.
Tontod,
As far as I know, there is no way to monitor the client from a console window while it's running as a service. However, if you turn logging on, you can check the log file and tell if it's running, the keyrate, etc..
Another really great way - if you have multiple machines, is to use ppstats.
You can set it up (whether static or dynamic ip) to segregate your machines by host and monitor production remotely from any machine that can reach your stats box via tcp/ip.
That's pretty cool. Last night, I pinged my wife - her machine hadn't checked in a block in over 2 hours. Gee - it was sitting at a login screen. We took care of that in a hurry.
If it hadn't been for ppstats - it would have sat idle for 16 hours.
