Necrosaro420
For some reason, it did not do this before, but now it is shaking a little.
I have the monitor set at 75mhz, but when I switch it to 60mhz, it will not shake (I would use it, but the screen will not fill up my monitor like that, and cant adjust it to fit correctly)
It is a Mag 19". It worked fine a while ago, but now when I turn it on, only at 75hz, which is what I had always used, it shakes!!! (also shakes at 70/72 but I do not like those frequencys)
Any ideas? I went to radio shack and bought a filter for it, but that did not help.
Thanks!
Thanks!
