Well, my display (an NEC MS FE791SB) has off and on had this shaking problem. I tried playing around with refresh rates (I'm running at 1280x1024, and previously had it set at the maximum possible refresh rate...thought that might be it) to no avail. It occured to me on several ocasions that it might be a power problem, however I have UPC and presumed this would provide more than the very simple protection I seem to be getting. Right now we have some workers in the house, and I can hear a saw go on and the monitor shakes. First off, is this bad for my monitor? I don't need a broken one. Second, is there something wrong with my UPC (Cyberpower 625AVR)...ie not strong enough for my system (what's listed below on an Antec 400W SmartPower PSU and the monitor are the only things plugged into the battery), or maybe I misinterpereted its feature set and it isn't doing any line scrubbing? Should I be concerned about anything, or just shut up and buy a good line scrubber? (And if that is the case, do you have any recommendations?)
