Hi
I have a KDS monitor. It's a VS-190i. The problem is with the length/width of the display. It is stuck at a certain spot and can not be moved! When I change the x/y axis using the buttons on the monitor it does not move. The % moves but the display sticks at once point. I have also tried adjusting it from the OS which my ATI software has but this does not fix it. What could be the problem? It also no longer has a warrenty! Thanks!
This is also at any resolution I try. 1600x1200 is the max.
