Monitor 25 feet away from PC, any other way to connect?
seiyafan
If I move monitor 25 feet away from PC, is there a way to make the connection besides getting a long cable? By the way it's DVI out.
Is there a distance limitation?
Yes. For digital DVI cables there is a 5 Meter distance limitation. If you go longer the video results will be unpredictable and not guaranteed. The only way to safely and efficiently go longer distances is to use OC and OLC series DVI fiber cables.
