I am replacing an AMD 200 system for a friend, and trying to keep costs low. Her case is perfectly fine and we want to use it for a Duron 1.2 Ghz and ECS K7S5A, I purchased an ATX AMD approved PS as well. From this AT power supply, there is a cable with thick outer covering going to power switch, it has four conductors. The colors are white, black, blue, and brown. I know black is ground, but what are the other three? The ECS board has two a two pin connector for power, being normal ATX. So I guess I will not use two of the conductors on the AT power switch? Could someone please tell me or point me to a site that explains AT power supplies, all of the AT power supplies I have used didn't have this separate cable (at least I think they didn't). Thanks!
Edit: Thanks to Warcon, I simply used the reset button as the power switch, and it works flawlessly. 🙂
