BonzaiDuck
Now I'm adding another thread, only vaguely related to the one I'd just posted about HTPC and Media Center.
The Logitech sound system I mention here is the sound system I might want to use concurrently with my AVR/HDTV setup.
The cabling for the system is limited. The center-speaker has the 6' wires with 3.5mm plugs that fit my PC. The speaker wires (AV/RCA plug-ins to the woofer) are much longer, so I can deploy the speakers in the corners of the room as I might desire. The woofer is connected to the center-speaker by a very thick cable -- also <= 6' in length.
If I can extend the 3.5mm-plug wires to the PC with simple 3.5mm stereo cables from Radio Shack, I can orient the center speaker and woofer on the opposite side of the room. There would be no requirement to lengthen either the Center-to-Woofer cable or the Woofer-to-satellite speaker wires.
What are the drawbacks with this? As I understand it, the longer the speaker wires (of either sort in this context) -- the more the power-loss.
Any thoughts about this? Moving the PC to the opposite side of the room is not an option at the moment, and I don't want to complicate my 4-PC-with-KVM-switch with wireless solutions.
