How to select an unregulated power adapter
With the concepts above considered, selecting an unregulated AC to DC power adapter for your application can be summarized as follows:
- if you're replacing an existing power adapter:
- choose an adapter matched as closely as possible to the original adapter's voltage and current specifications.
- determine the required adapter DC output plug size and polarity. There are many possible sizes.
- the DC output connector at the end of the cord can be changed or removed if necessary, but if you do this, the adapter can't be returned to the store.
- When choosing an unknown power adapter for your own application:
- determine the power requirements (voltage and current needs) of your load device or circuit.
- select a power adapter with a voltage and current rating that matches the load requirements as closely as possible.
- the maximum current requirements of the load should not exceed the maximum current rating of the power adapter.
- a power adapter that can provide more current than the load requires will sometimes work, but if the current difference is very large (say 30 to 50%) be aware that "ripple voltage" on the adapter output may be higher than ideal, and a filtering capacitor may be required to smooth out the DC output voltage of the adapter.
- care should be take to ensure that the maximum input voltage of the load device is not exceeded.
Source: http://www.apogeekits.com/power_adapter_selection.htm
