Modem Problem In WinMe!
SGtheArtist
508
I've been in the process of making the move to Windows Me over the last couple of weeks testing and ironing out whether or not things I used on 98 would work in Me and so now I'm down to my last problem. I have established that my modem (An ISA V.90 56K Voice modem w/fax internal w/Rockwell 5614Jx(G) drivers), which works fine in 98 acquires a small problem with Windows Me. Also, the phone line is routed through the modem before being connect to the phone. Now let me clarify, I have eliminated the possibility of software issues, driver issues, and motherboard setting issues. So I know it lies in somewhere with Windows Me, now to the problem, whenever i receive an incoming call & my computer is on (but not on the internet, I only have one phone line.) when I answer the phone my computer / modem kicks in and begins to try and communicate as if it was trying to send a fax or connect to the internet, and therefore interupts the phone call. This problem does not occur when I make a call however.
When I try and install my modem after a clean format and install for WinMe onto the HDD WinMe cannot detect the modem however if I install the driver and go to the diagnoistic properties to see if the device is working properly it says that it is with no problems, which is semi-true because I have no problems connecting to the internet, which means that the modem is working fine. Soooo, my question is what should I do now to try and find a solution to this problem?
P.S. I have a second computer, which has WinMe and while on does not present this problem nor trigger it for this computer. I also have Call Notes, however I do not believe this is to blame either. The reason I have eliminated these from the possible causes is because this environment existed before my move towards WinMe and while using 98 I did not encounter this problem.
Thanks for everyones input and help.
