Modding ideas for new lian li case
LOL, but you only gave us 56 minutes 😉
My suggestion: start by cutting out the grille over the rear fan, and get a holesaw and cut a second rear exhaust hole below the first one. Use chromed wire grilles for low restriction.
Nextly, check out these Coolermaster thingies and see if any of them turn you on: Coolermaster bay-dwelling thingies
Beyond that, it's up to you whether you want to follow the usual window-&-lights routine.
I've the same case only black.
I replaced the fans on top and rear with 3-color fans.
And that's about it. 🙁
127 bucks for a case without power supply? I'd rather put my money INTO my box, not spend it ON my box.
I'd suggest you build your system and live with it for a while before doing any hacking. I'm the happy owner of a PC-65b, and it's just too nice to hack up with unneccessary "mods".
Most of the things I've done over the 8 months I've had this case were performance-oriented, such as cutting out the rear grill for better exhaust air flow, and opening up the "louvers" on the top blowhole .(almost a 50% increase in airflow!)
I did originally stealth the CD drives, but I recently went to the factory "stealth" panel on the CD reader, as I got one at a great price. I'd suggest using those vs. home-made on a new build, they look great and work very well!
