squelchy451
Hi. I have a shuttle case and the included cooler's not really cutting it, so I'm looking at the closed-loop systems, more specifically the Kuhler 620.
The fan mount for the shuttle is a 80mm, and the radiator for the 620 is 120mm. Is it possible at all to replace the 120mm radiator that comes with the kuhler with a 80mm one?
I don't have the Kuhler yet and I'm open to the Corsair varieties as well. My top priority is the ability to mod the cooler to use a 80mm radiator rather than a 120mm one.
Thank you
Thank you
