modding case..
rear is tough cause it doesnt fit a 120 without extensive modding, but top and side can be done buy purchasing a holesaw bit for your powerdrill, that'd be your cheapest bet
Side window sounds good. Not rear. Where are you gonna fit a window in there?
Also top fan sounds good.
Maybe you could just borrow a dremel from someone?
rear i want to make a bigger hole insted of 80mm a 120mm... no windows just bigger holes for fans...is anyone around phlladelphia to tell me where can i go to do it??
thnk you guys
sheet metal shop be my best guess
second is to buy a holesaw do it yourself
or dremal
have to be carefull when useing power tools
Jen
