Window without fans maybe - with fans probably not. Likely won't clear PSU or top 5" drive bay. Blow holes don't do much for cooling and may starve PSU for air.
Overkill for a 3700AMB, it already has a 120mm intake AND exhaust. If you want to exhaust more warm air from inside your case get a AC silencer for your GPU
Did you read what I wrote earlier? If you want to do a 120mm blow hole w/o buying any rip off kits, go get a CD/DVD (same size as 120mm), put it over the spot you want the hole to be, trace the circle, drill a hole in the middle and saw your way out and around the circle and you're done.
