I've noticed my Ultra X-Connect 500W PSU is pretty loud most of the time. so, I was thinking of swapping out the (2) 80mm fans for just (1) 92mm fan.
The 92mm is rated for the same airflow as the 80mm's I believe.
http://www.newegg.com/Product/Product.asp?Item=N82E16835119034
I've already taken the PSU apart and a 92mm will fit easily, a 100mm would if I could find one.
Do you think this is worth the time? / would work?
The 92mm fan is rated 10+ db lower than the ultra fans
