Originally posted by: JimPhelpsMI
Hi, No big mods necessary. If it's an AT PSU then a DPDT switch can be added to the 4 conductor heavy AC leads to turn it on and off. If an ATX PSU then a momentary N. O. push button switch can be connected between the Green wire and any Black wire in the Mother board connector. Hope this helps a bit, Jim
Hi, If you used the AT PSU with a toggle switch that switch would turn it on and off. If you use the ATX then the momentary button will turn it on an off same as if in your machine. Jim
