I just mod the maxtor ata 100 ultra card into a fasttrak100 using the methods given by tweakhardware.com
it was firmed and detected as a fasttrak both in boot up and in w2k.
to test the card.
i did a raid 0 (strip) with 2 harddrive (no they are not identicaly, i know the rules about it)
raid was successful when one harddrive is slave and the other is master on primary ide
problem:
i tried to put both harddrive on master on different ide (ide 1 and ide 2)
fasttrak mod card does not reconignize the 2nd harddrive
is there a problem? did i do something wrong with the moding.
i did part b on both step 2 and 4 on moding hte ata card, and it is promise ultra100 when i bought it
thanks for you help
to test the card.
problem:
thanks for you help
