Mobo Won't power up?
kamuell
Doing my usual 2-3 year upgrade and actually went with a few of Anandtech's recommendations (or Jarred Walton's recs).. picked up a DFI Infinity Ultra-II M2 AM2 for the mobo. Along with:
2x1GB Corsair value select
AMD Athlon 64 X2 3800
EVGA 256-P2-N550 -T2 GeForce 7600GT
FSP Group 450W (AX450-PN)
Anyway, so I loaded the mobo up with all the parts... plugged it into the wall, flipped on the PS and hit the mobo's power button - nothing. Hm ok, unplug from wall - hook up the case's power button to the correct jumper (thought maybe the mobo's on board power button was cashed). plugged back in, hit power button - nothing. not even a twitch of a fan, or a beep - i mean NOTHING. No fan even started up (not even the PS one).
Thinking it might be the PS, I took my old Abit NF7 and plugged the new PS into that - turned right on. Okay so its not the PS.
Next, I removed EVERY part from the mobo, including ram. I'm only left with the PS plugged into the mobo, and the CPU/heatsink. Nothing else. Plugged it in, hit the power - nothing again. That's when I notice there is one little LED lower on the board which is on. ends up this is the "standy power LED" .... the manual is not much help here.
So it has to be a bad mobo right? Is it possible its anything else? I mean with NOTHING else plugged in, I don't even get a twitch from the heatsink fan etc
(also can i just mention that this power supply shows 115 on the back ... i'm used to seeing 110....?)
happened to me. both times were due to a short circuit.
left a screw that found its way under the MB
crimped a ps wire when sliding down the hd enclosure. shorts suck
take it apart again and do it one more time
thanks for the response serrow... i'll give it a try.... someone in the "tech problems" forum suggested trying it on a phonebook.
