Mobo Sound (DFI Lanparty NF2) vs Audigy 1
Slash621
I have a SB audigy 1.. my speakers are logitec Z560's (4.1)... I am most interested in gaming, i dont need max performance for watching movies... 3d positional sound is quite important to me becasue of games like CS and of course the up and coming HL2.
My setup is listed below, along with stuff that is "on the way". But i still have an audigy 1, which would give me better quality, and better performance (reqiring less from the CPU)?
Mike
The chip on the motherboard is on par with an Audigy1 minus Creative's bloatware drivers. The Nvidia drivers aren't much better, but they aren't bloated. The Nvidia sound is a full-fledged harware solution unlike most onboard sound. I'd just use the onboard sound for simplicity's sake. The Nvidia sound on my board (Asus A7N8X Deluxe, the same as your sound) is great and I wouldn't bother getting an add-on card unless you need the extras the card gives you.
The Audigy will sound better, but creative makes the worst drivers known to man. I could never get my system fully stable until I took my audigy 2 out and used the onboard sound...
As long as you get the drivers and only the drivers, everything goes fine. Don't even put in the CD that comes w/ their cards... It's full of bloatware (mediasource, blah blah blah)
Just go to the website and get the WDM Driver Package.
Mike
I think the mobo onboard sound will perform better. Here is an article comparing the onboard sound of the Asus with Audigy 2.
But they found the Audigy 2 a lil better than the Asus onboard sound.
Comparison of Audigy2 and Asus onboard
That's the Audigy2, he has an Audigy1. Different ball of wax (not by much, but still different). The Audigy2 was a little bit better sounding than the Audigy1, and the Audigy2 is a little bit better than the nForce sound. Conclusion: Audigy1 and nForce are about the same.
Hi all, I hope no one minds me giving my honest opinion.
I have an Audigy, and have been very very happy with it for a long time. When DFI started sending me boards, they asked me (basically made me lol) to give the SoundStorm audio a try on the NF2. I've always hated onboard audio, and for a good reason: its always been total crap (mostly).
Skeptical, I decided to load up the first time with my Audigy (its like cigs for me...near impossible to let go as I have never had a problem with it, and its always sounded awesome). Perfect on the DFI NF2, no special settings or such to make it work properly. I had it on for about a month.
Then it was time to run RAID0 on the board for a customer (this is my personal machine btw, and there is ALWAYS winamp running something). Plus I had a question about the SS audio and how good it was, so upon a fresh install of XP, I used the onboard audio. It took me a minute to get the speaker setups going the way I wanted (I don't use the SPDIF but have 5.1's with the 3 plugs). To get the 5.1 properly configured, I had to use a PCI slot bracket thing with the extra C/Sub and Rear jack, but otherwise was no problem (btw, if you use the 5.1 analog instead of digital, and you need one of these brackets for your DFI, just ask, ill ship one for free).
so what does this have to do with sound? Well, amazingly, the SS audio was as good if not better than my Audigy. I play things loud and long, usually cranked while im building/destroying a machine in the comp room. Very clear, high quality audio. Im maybe not an expert on sound, but it truly sounds as good. Just as a reference, I put the Audigy in the KT400A LanParty and ran the same songs and just switched speakers from one to the other during songs and did this for a while. Sounded the same to me.
But
the one thing that the onboard apu does that the Audigy NEVER did, was 'skip' through mp3's. Its hard to explain, but I get these random stutters like the cassette is being eaten up lol. Sometimes its a short quick 'squelch', and other times the song starts to skip so bad that I have to hit 'next' to change songs and all the sudden its ok again. Its very random, but often enough to anger me =). Its not the crackling/popping of normal crappy VIA onboard audio. Again, its very much equal to an Audigy. But these random patterns of squelching and noise are irritating. I've reloaded XP once again, just to make sure, and before I loaded any other programs (after all updates of course), i put winamp on and some music. Within an hour it started up again. I've asked other SS Audio users if they encounter weird random issues like this, and most have. Most also like their SS onboard audio more than their Audigy so they put up with it. I must also as I have not put my Audigy back in.
In games, the onboard SS audio doesn't cause a performance hit that I can see. I always play with 3d audio or EAX enabled and such, and I can't notice any performance loss, and when I hear footsteps in Urban Terror coming in from the upper left on the ledge above me in my blind spot, I can tell thats exactly where its coming from...so that tells me that its got excellent 3d again very much on par with the Audigy.
Bottom line:
use the onboard SS audio that comes on the DFI LanParty 2. I think you will like it. If not, pop the Audigy back in and see if you can tell the difference. Its a user choice, and one way or another you will be satisfied with the audio if you already like your Audigy1. Im not such an expert in sound that I can tell the difference in the Audigy and Audigy2 either (I've heard them side-by-side).
sorry it was a novel. =)
Travis
