MOBO replacement HELP pls :-)
hexcore
Hiya guys, can anyone please help me, my mothers pc had some idiot friend of the family knock his can of coke over the top of my mothers pc its wiped out the MOBO & GPU but the rest is fine, ive been looking for the same board but as its 4 years old i cant get it for a justifiable price, for the price ive seen it for i can get an upgraded board instead?, anyways the Mobo she has which is dead is a
"Asus P5P41T/USB3 Intel P41 (Socket 775)"
& an
"Intel Q6600 Core 2 Quad Q6600 2.4GHz 8m Quad Core 1066mhz" CPU
with
"DDR3 1333 2gx16 u dimm" Ram, (she has x4 gig)
Can anyone using the same CPU and RAM that ive salvaged from her pc tell me a mobo which i can use as an alternative to the dead board pls? i would be EXTREMELY greatfull for any help!
Many thanks :)
IntelEnthusiast
Intel Representative
Feb 10, 2011
582
Here are some boards that will support that processor and all of them except the Intel DG41RQ will support DDR 3 memory but it would be overclocking to reach the DDR 3 1333. So you can run the memory at a slower slow without any problems.
tweakboy
9,517
www.hammiestudios.com
& an
with
Many thanks :)
grab a P5Q and do a repair install of windows and you should be set to go. :rolleyes:
