mobo problems
Hans5849
217
ok, i have a brand new ic7-g and for some reason when i have my usb keyboard connected to usb port windows won't recognize it the windows install won't even recognize it to let me reinstall. and when i use the usb-ps2 adapter i can't use the shift key, crtl, or alt keys. do you think the usb connectors are bad, and i should rma the mobo
MichaelD
31,528
In the bios, there's probably a setting for Enable USB Keyboard. It's usually turned off by default. Check that.
Hans5849
217
my ms gavevoice doesn't light up when its pluggeed in, it deteced the printer. wben ever i touch a usb cable to try and plug it in or to remove it the computer locks up and restarts
and windows detects one of my hard drives but it won't show the contents, it says that it is not accesable
