I tried with a maxtor 80gb and a seagate 200gb on the albertron K8X800 mobo. the hdd won't power up when the ide cable is plugged into the mobo. when I disconnect it, it power up.
I don't know what is causing it, but this is driving me crazy.
it wont spin up at all with the ide connected? but it does spin up if the ide cable isnt connected? do i understand that right?
first thing i would do is set teh bios to "default"
have you double checked that the cable isnt backward?
have you tried using a different ide cable?
also have you tried plugging it into the different ide port? (ie use secondary port)
I changed the bios to default.
I tried both way, not working.
I tried with a different ide cable. (i am gonna try it more)
I tired both primary and secondary port too.
Originally posted by: Subhuman25
Is/are your HD jumpers set correctly i.e. MASTER/SLAVE/CABLE SELECT?
Are either of them sharing the IDE channel with an optical drive?
