- Aug 11, 2004
- 9
- 0
- 0
I had an odd failure of my mobo, or power supply, or perhaps both, recently. My system is an ECS K7S5A mobo with a 2000+ Athlon XP, an NVidia ti4200 video card, a Soundblaster PC 128 soundcard, a D-Link 503TX+ LAN card, and a standard CD-ROM, 80-gig HD, and floppy drive. The computer started just going into what appeared to be some kind of state of suspension at random thimes; it would switch to a blank screen, bu the fan on the CPU would keep running. I swapped memory and video, and when I got into the case to pull the CPU I found that, when I pulled the ATX conector off the mobo, about five of the connectors had various degrees of charredness. In particular, the top left lead connector was almost completely burned, and in fact most of it stayed in the motherboard as black crud when I pulled the connector. Whwn I cracked the PS case, though, I saw nothing amiss. At this point, the connector on coth the mobo and the PS are possibly too damaged to repair. More to the point, until I figure out whether the PS or the mobo is the problem, I don't want to use either. Has anyone else had this problem and if so, found a repair or solution?
