- Jul 22, 2011
- 229
- 38
- 91
Ok, so I just got a new Gigabyte mobo for my comp:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128627
I also have a very old Sound Blaster Audigy SE sound card. I am wondering if I would be better off with the on-board audio from the Gigabyte, or if I should use the SB card? Does it make any difference as far as system resources? What about sound quality?
My issue at this point is that with how old the SB card is, the drivers for it aren't supported. As such, I have no equalizer and none of the other audio effects work either. I tried the Daniel_K support pack, but none of those functions work on there either. I am also on a very tight budget right now, so I won't be able to get another sound card for at least a month.
