just in general, a gtx570 at 1440x900 would be silly. and with your stock cpu it would be beyond silly.PSU cooler master real power 550watts
resolution: 1440*900
its still silly. lol, that would be like me using my gtx260 at an insanely low res like 1024x768. you do not need to blow over 300 bucks on a new gpu for 1440x900. your gtx275 is plenty fast for that low resolution.i can fix the stock the cpu issue by oc'ng it to 3.2 ghz...........frm stock 2.66ghz.....will it still be an issue
why do you have to spend 400 bucks right now? cant you save it or did someone give you 24hrs to spend it or lose it? lolok...........lets say i got 400 bucks wat shld i upgrade cpu+mobo(intelQ9400) or GPU(GTX275)
Maybe his motherboard is causing large numbers of exclamation points to appear when he types thread titles?I'm still trying to figure out what is so urgent.....
my pc secs are
CPU intel core 2 quad 9400(will this be a bottleneck)
ram 4GB
psu cooler master 550 watts.........its got two 12v gpu connectors with 18A and 20A respectively
