- Oct 23, 2007
- 19
- 0
- 66
I've been building computers for gaming for over a decade now, but I'm into new territory here and trying to keep this on a budget so I'm reaching out to the forum. I'll need to give a little background so bear with me. What I want to do is put a box together and then use VMware to slice it into 4 smaller boxes running CentOS on all 4. I'll be using VMware ESX so I can run it directly on the hardware without a host OS. Now, I'm an Oracle DBA and I'm getting into Oracle's Application Server for the first time so I need to set up a test box, but at the same time my home server box is getting a little long in the tooth so I figured I'd kill 2 birds with one stone and do both things at the same time.
For anyone who has Oracle experience (everyone else can skip this part), what I plan on doing with the virtual boxes is to use 2 as a 2-node RAC/ASM database cluster and then build out the App Server onto the other 2 boxes using one as the infrastructure layer and the other as mid-tier. The mid-tier will also function as the all-purpose-grunt gateway/DHCP/webhosting/etc box.
I've been working with our sr. sysadmin on getting VMware to simulate the environments, and even cumulatively, there's not going to be a lot of processing. I should be able to get away with a quad-core Intel Q8200 w/ 4MB of RAM, with intention of giving each box 1 core and 1G (I might adjust that as time goes on). I also think I can get away with a single SATA HDD, again because IO should be a minimum, and I *should* be able to bridge all the virtual network cards to a single device (I haven't looked into how this will effect DHCP, so that duty might get moved back to the router for our house computers, giving the bridged cards static-IPs).
So what I need is a good, stable motherboard that's compatible with VMware and doesn't mind being on 24x7x365. I don't mind paying for quality but at the same time I'm helping my future wife's parents pay for our wedding and then there's furniture, honeymoon, rent ... you get the idea. Budget is the order of the day, but as I said, I'll always pony up the cash for quality so I get what I'm looking for.
If anyone has any recommendations or has used products in similar ways, I'd be grateful for the input.
Thanks!
Thanks!
